82-70 mp chassis no pindeck light
  • 82-70 mp chassis no pindeck light
    82-70 single board chassis everything is working fine on this lane just has no pindeck light i have put 3 different working chassis on this lane and does the same thing everything works just no pindeck light c1 plug looks good
    Check for voltage at the light receptacle in the front wireway? I'm assuming you also checked the starter and bulb in the fixture?
      I've got a cord that allows me to plug the pit light into a regular receptacle. When I have a pit light issue where I know the light itself is good I can bypass everything to get it running for the moment and fix it later. Same situation for BE motor. Couple of handy things to have hanging on the wall.
        Pit light would be your C!, 5th from the right or 4th from the end(Top Row). S Red 4 / M Relay, #6
          thanks felix u just helped me out alot man thanks again man
            have you or anyone else changed the receptacle on the main plug-machine side(not the pindeck light plug)?...if so,perhaps the hot and neutral wires were place on the wrong terminal...that would cause pindeck light issues...
              So we are sure the pindeck light does not have any lamp, starter, ballast, socket, cord or plug issues?
