Broken Snap Ring Gearbox
  • Broken Snap Ring Gearbox
    Has anyone had to deal with a broken snap ring inside a national gearbox? The ear of the snap ring is broken off. If so how did you get in off? I am afraid that I will be ending up buying a new shaft if I have to take a dremal tool to it. So I am looking for any other alternatives. Thanks in advance.
    I had a similar thing happen once, I used the circlip pliers and forced the one remaining tab out of the groove slightly and then with a flat blade screwdriver kept prying it out took a while but finally got it...
      I've used the handle end of a round file (plastic off leaves a pointy end) get it started and work it around with a screw driver.
        I've literally jammed the snap ring pliers down the "crack" between where the tabs are supposed to be, with a persuader and just mauled/bent the old snap ring off...sure its rough on the tools but its small potatoes next to a unusable gearbox. and you better not leave a bad snap ring in there, I did that once and it worked its way off the shaft into the bearing (ruined), around the agitator gear (chipped tooth) and ruined the other brass gear on the pinwheel shaft in a national BE. plus the rest of the gearbox was being lubricated with shavings and chunks so uhhh really suggest you don't do that.
          I hear you there on not leaving the broken snap ring. If it broke once it will break again if left and not replaced with a new one. I have been going through all my gearboxes and flushing them out because I had one get stopped up because of broken parts. Have found two sun gears that are chewed up because of broken bearings or snap rings. So I have a big task at had going through all 20 lanes worth of gear boxes to make sure that doesn't happen again. Or at least limit the chances hopefully. Sometimes you just can't catch a bad bearing going in a gearbox.
            Got it off finally, used a small screwdriver and got part of the lip up and out after a little more persuasion and some vise grip I got it off. Thanks!
              SMILE! TOMORROW'S GOING TO BE WORSE
