Distributor spring mod
  • Distributor spring mod
    No more swaying!
    interesting mod increased tension on both sides (wonder if clutch has to work harder now) always thought just increasing tension on the right hand spring (or replacing with a new spring ) fixes swaying from #3 to #2 bins
      Often find, sway from the 3-2 pin is over tensioned clutch spring... and occasionally the support tube the dizzy casting slides over has not been secured with Loc-Tite... so it rotates with the casting and can jam at certain spots..
      But cool mod Dave, I reckon that is BETTER than cable ties on the springs, your way at least doesn't ruin the springs...
        Yeah it is better than the ball return spring wrapped around the thing as I have saw on a few machines. Interesting comment Pin Head... I assume you are talking about that bar that falls out of the bottom of the dizzy accasionaly when I take one off?? If so, they are better secured with loc tite, no ****? Let me know if I am on the same page with you as I will have to try that! Thanks
        Dave
          I just got my mouth washed with soap by bowltech! LOL.. Sorry bowltech, I will watch my cursing!
            Dave
            That's the one mate, yeah that post is NOT meant to come out when you lift the dizzy up... as I am at home now, I can't recall exactly what number Loc-Tite to use but the manual shows which one.... But yeah Dave once you have the posts secured it will really make a difference, as the dizzy will now rotate on the support shaft instead of the shaft rotating in the housing.
              Interesting that you guys bring up sloppy distributor support posts.
              A while ago, I had been having trouble with a few distributors because the posts and the tube they sit in were worn out, very old. This made the distributor sort of bounce up and down and made it move in a sloppy way, causing problems. Since I could not throw away the supports and posts and put in new ones and since I don't like the idea of just using locktite on them, I came up with a mod from a part from the 82/70 A/B machines.
              My machines are mostly C machines in the main center with some backends from what I believe to be B machines. The A and B machines had a different type of distributor support, and if you ask me, because of this one part of it, a better one. The A and B distributor support is a casting with a tube that bolts to the cross beam, not a peice of curved steel. Now for the real interesting part, the part that gave me the idea, the support post does not just sit in the support, it is SECURED with a .... wait for it..... wait for it..... CLAMP STUD! Yep, a big honkin clamp stud keeps the support post in place, as seen below...
              So back to my problem posts. The sloppy posts were the ones of the newer curved metal support type, my machines have a mix of both. So I figured there was a way to secure the post in place like the old style supports, and there is. All you have to do is on the front of the tube the post sits in, low enough to clear the distributor and exactly centered, drill a hole (with the post removed) and tap it. Then install a short bolt with the post back in and what do you have? A distributor support post that WILL NOT EVER MOVE and the added bonus is if for some reason you ever need to take it out, just loosen the bolt!
              Here are a couple of pics to show this...
              Now I know the distributor support on a 90+ is different but it does have basically the same tube and post and I believe this mod can be added to it as well.
                Nice work on fixing the supportTJ - and the spring mod looks awesome too!
                  Saved a lot of money too and why junk this stuff when it is still basically perfectly good.
                    SWWWEEEETTTT! I like it! I really want to say a cuss word right now!
                      You need some more grease on that post tablejam jk.
                      That's a cool idea though with a bolt. If I had the newer supports and found that a loose post was a problem I would be doing that to all of them. But all of my distributor supports are the older kind
                        You can do that Dave... but you gotta use the right symbol! (type in 'curse' with a : on each end)
                        We'll get the idea.
                        Nice mods guys.
                        PinCup
                        TJ, I think your dizzy post need more grease!
                          It doesn't have enough grease, actually, that's better than not having any grease.
                          LOL.... WTF?
                            I dont use grease on the post, but gear oil. Works great and doesnt gum up.
                              Couple other mods to help with the sway are to zip tie part of the spring coils to make it tighter and use a spring on the "left to right" arm up to one of the O pan bolts.
