Sweep/ circuit fault ?
  • Sweep/ circuit fault ?
    Ok I have a strange one on a 70, mp chassis .
    Every so often the sweep is just dropping to guard on its own, we've changed chassis, pc board, motor, sweep run switch. A cam set up has been done.
    once the sweep is at guard it just stays there till we put the sweep back up manually...
    any suggestions guys
    Thanks
    Sounds like it's REALLY coasting. Check the lowers on the sweep contactor.
      Think I Found it.. One of the screw from the emergency stop had worked loose and fallen off. It was shorting across two terminals.
