5 Conductor Table Motor Cord
Im pretty sure the table motor only uses 3 wires. The sweep cable uses 5 because of sweep reverse. I could be wrong though cause i havent dug into the table plug in awhileGiving bowlers less to complain about, one lane at a time
Originally posted by 70/70 View Postopen your table plug. Pretty sure you will find only 3 conductors are used
On the table you have +, -, and ground at the plug plus a jumper between the other two terminals. On some of mine there are 5 wires at the plug with this jumper figured in at the terminal strip. I don't know if this was done after the fact or if it was like this on B machines but that's what I got on some of them and it works fine.
I should clarify my configuration. All my machines have 5 wire conductor cord but only three are used with a jumper in the plug.
Paper clip??? Not only is that unsafe but against electrical code. Use proper conductors with proper insulation and proper installation and you won't get some one hurt or killed by getting shocked unexpectedly and fall off the pinsetter or get electrocuted. I don't mean to sound harsh but this is serious stuff.
When using the new cable, connections are made: the Black Wire goes to TS-22, Green Wire to TS-20, and White Wire to TS-1A1. No connections are made to TS-13 with the new cable. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
We also have the 16/3 SOOW wire with a jumper at the plugs here.
I'll just leave this here...
