Options ball return not starting on even lane.
  • Options ball return not starting on even lane.
    The odd lane on the pair does turn the lift on but the even does not. I thought it would be in A&MC box not sure but thinking terminals 5 and 6? I'd rule out the fuses and the board since the even fires it up fine. could be wrong though, any ideas?
    i have had this problem but it has been awhile. if i remember right mine was in the chassis. i dont remember what location it was at but i tried a swap and both odd and even started working proper. have you tried a swap?
    watch out, they're everywhere!
      I would suggest swapping chassis to start with and if the problem is still there then check the front end relay
        Is the even lane getting the signal to turn on at the powerlift? If you swap the signal cables between the odd and even lanes at the powerlift control box what happens? That would tell you if the problem is at the powerlift or anywhere between the powerlift and the chassis.
