Relays "Contacts"
  • Relays "Contacts"
    I recd. a relay in yesterday and it's not the same no.I wanted an eaton xtrm10a22t I recd. an xtre10b22 would this work.
    My gut feeling is no don't even try get the right one.My luck i'll blow up my M.P Chassis but just wondering. It has all the same
    number of inputs all the right numbers on top but it is different.
    Thanks Scott
    Is this a 'ice cube' relay or a contactor?
    If it's a 'ice cube' type, as long as it is a 3PDT type with a 24VAC coil, you should be fine. If it's a contactor, as long as it's a DPDT type with a 24VAC coil, probably good to go. Can you post a pic. of it?
      this chart has the details and specifics but
      Yes actually they are interchangeable, one is a mini size and the other is standard size. Same ratings and same NO and NC terms as you saw. so if you just hook everything NC up to NC and NO up to NO you will be gravy.
        Thanks Grit
        And yes Jon it's the ice cube type all enclosed not the old open contact style
        Can't really post a pic. sorry
          OK - like Grit said, you should be OK.
            "Ice cube" refers to the plug in relays such as for M, M2, and SPOT.
