MP Chassis T-1 Wiring
  • MP Chassis T-1 Wiring
    I have a question on the wiring for T1 on an MP chassis. I had to replace T1, the output to the mask bulbs was shot and causing Accuscore not to score second ball as a result. I ordered a new transformer, part # 762 011 011. I just got it in. The replacement transformer is dual voltage, both 115 and 230. There are four black wires for the primary side. An all black wire, a black wire with a yellow stripe, a black wire with a green stripe, and a black wire with a red stripe. My question does anyone know which wires do I use for 115 volts?
    The wires for the first primary are Black & Red/Black and the 2nd primary are Black/Yellow & Black/Green. Wire them in parallel. If you need further assistance, just give me a call. 866-460-7263 option 4.
    Regards,
    Billy T
    bthompson@qubicaamf.us
      Thanks for the info Billy.
      Brian
        To clarify, Connect the Black and Black/Yellow together and the Black/Red and Black/Green together, then these two get tied into your incoming 120VAC power source.
        Regards,
        Billy T
          Thanks again Billy. The chassis is working well.
          Brian
