82-90XL silver chassis
  • 82-90XL silver chassis
    got a pair of lanes (7and8) that for no reason just shut off in the middle of a game. have to turn them on manually in the back af ter they do it. i assume it is the chassis but it is so intermittent. maybe once every week or two it will do it.
    baffeled.
    When you get to the lane when this happens are any of the LED's on the front of the chassis on?
    Regards,
    Billy T
    bthompson@qubicaamf.us
      Please check all connections to and from chassis also scoring connections.
      As both lanes are involved, check camera and connections or cable under capping being hit by ball and momentarily dropping signal.
      BOTH lanes closing means it must be something common to both lanes.
      e.g. camera or scoring side.
      good luck
      maister
        Ide check your communication end first ie scorin side camara cpu could even be a loose connection
