Your post should include the following:
-the original problem
-the solution or modification
-the steps and parts needed to install the mod
-an explanation of what the mod does to solve the problem
-pics showing the before (if possible) and after
I'll start. I have some below...
1. Problem: distributor post is sloppy in support bracket, causing distributor to bounce up and down. This can lead to pinfeed problems. Solution: instead of replacing an otherwise perfectly good distributor support, just add a set screw to keep the post tight. All you need to do is drill a hole on the front of the tube on the support, low enough so that the distributor casting has clearance and centered, then tap it and install a short bolt. I used a 1/4" coarse tap and bolt. What this does is tightly clamp the support post in place and eliminates the up and down bounce while saving money on re-using an otherwise perfectly good part...
2. If you have any version of AMF scoring then this is a must. Problem: scoring when it should not or double scoring on a sweep reverse/gutter ball. This problem is due to the fact that the sweep zero switch is far from the sweep link, leaving very little room for error. The tiniest bit of sweep coast will close the switch and cause it to score when it should not. Solution: all you need to do is mount the sweep zero switch closer to the sweep link and to do that you just flip the slotted bracket around and mount the switch and adjust for clearance. What this does is mount the switch assembly much closer to the sweep link giving it much more room for error, even if the sweep is coasting a little it will stop the scoring issue.
Before...
After...
3. Problem, at the 2 and/or 3 in the bin, the second pin sometimes goes past the pin butt guide, then both pins shuttle and jam in the table. Solution... install an extra pin guide to block the second pin. Just add another "hook" pinguide to the outside of the pin butt guide, bend the top up (bending it up to be horizontal seems to work much better) and twist it to face the distributor. Now, the second pin will hit this guide stopping it from following the first one through the shuttle....
Well that's some of mine, now let's see yours. Maybe if this is popular enough it will become a sticky thread.
