belt guard dist mod
  • belt guard dist mod
    Anyone used belt guard for this mod? 070-007-137?
    Like the poly-v belts for its grip but dislike the agressive turning of the pins from the pan to the belt.
    The mod let the head of the pin stay between the walls.
    I know this mod already exist but anyone use the belt guard for this?
    That is a SWEET mod! Thanks I've been lookin for something to stop the 'coptering.
      I've seen a similar mod for twister pins in a 70. A mini guardrail to keep the twisters for twistering off the belt.
      If you remove the "belt saver" from under the dizzy belt, that will lessen the aggressive turning at the pan by making the pan/belt OEM deep.
      I think the original idea was to get the belt higher and turn pins quicker. I was never a fan of them. Some machines run OK with them, others... I've thrown that little plastic POS across the shop into the circular file.
      PinCup
        I've found that having a pin seater on your guide rail calms down butt first pins dramatically and they won't roll off the pan. I've also found that when using a pin seater on the rail with a poly v belt sometimes the belt riser is needed or else pins won't roll out correctly. This isn't an issue with the thicker grey gripper and black rough top belts though. Isn't pin feed fun?
          This could have been posted in the "show us your mods" thread.....
            I've seen various ways this has been tried. From using a ball lift drive belt tensioner spring with holes in the pan and belt runner to a pair of vice grips clamped to the end of the pan.
              That is one of 2 good places for the belt guard - the other is the trash can
                Never used them, I use the Tuffy pin guides on all my machines and the ones I've had problems with the pins rolling of the dist. Stahls has a side rail you can install extending the pan. Don't really ever get pin upside down pileups.
                Joshua Knight - Stand By A Mechanic
                USBC Open Championships El Paso, TX 2015
                  Ha Ha exactly what I was thinking King! Finally the belt guard has an actual use! I knew I kept all of mine for a reason.
