AMF Motor Gear Lube Question
The AMF motor repair manual says "Apply a thin coat of Prussian Blue or Red Lead to the worm" in reference to rebuilding a motor. I can only fine a product by Permatex called Prussian Blue, and the description does not seem to be the right kind of thing. I'm curious what most of you do? There didn't appear to be anything on my gears, so I presume the gear oil does most of the work? I don't have any wear on the gears, so do I even need to apply anything to the worm or other gears and bearings in the motor? Thanks!82-70 MP Pinsetters+Humpback/Light Ball Clutch/Rocket Rails
*Monitor repair for Steltronic Elex/SuperElex system! Send me PM!Tags: None
I am not positive here but I think that that stuff was to see if the worm and wheel were centered during assembly. I guess that you would put it on then together spin it a few revolutions and see if it is shimmed correct.
But that is just a guess!!!70's MP/PBL/LBS,Q-Score
Prolane Walker sport
I think Keeth has pretty much got it. We use what is safely called "gear marking compound" (you can google it). We paint aproximately 10 of the worm wheel teeth with it and run the gearbox for about 10 minutes (under load). We then remove the worm shaft and make adustments to the shims for the wheel bearing races based on the wear pattern shown on the worm gear.
Originally posted by BillyT4QAMF View PostI think Keeth has pretty much got it. We use what is safely called "gear marking compound" (you can google it). We paint aproximately 10 of the worm wheel teeth with it and run the gearbox for about 10 minutes (under load). We then remove the worm shaft and make adustments to the shims for the wheel bearing races based on the wear pattern shown on the worm gear.Last edited by Bowling_Bias; 09-13-2012, 12:04 AM.82-70 MP Pinsetters+Humpback/Light Ball Clutch/Rocket Rails
