another table problem...................................
so after a huge bang last night it was a table hitting the pin deck. the threaded link to the bearing on the table drive broke. it was clearly in a bind..i replace all that...leveled table made a level bubble and all the pins are perfectly on spot..however the latch that grabs the spot arm to keep the cups tipped is to far forward this not grabbing it and holding it in spotting mode.i can't adjust the spotting rod far enough to make it happen which i don't really want to do anyway to change when the cups pull away from the pins...is it possible that spot lever with the single spring on it is bent? the rod clearly has to be made much longer but it can't be or the spotting will be incorrect.. any suggestions?mrmoparTags: None
Originally posted by mrmoparbair View Postso after a huge bang last night it was a table hitting the pin deck. the threaded link to the bearing on the table drive broke. it was clearly in a bind..i replace all that...leveled table made a level bubble and all the pins are perfectly on spot..however the latch that grabs the spot arm to keep the cups tipped is to far forward this not grabbing it and holding it in spotting mode.i can't adjust the spotting rod far enough to make it happen which i don't really want to do anyway to change when the cups pull away from the pins...is it possible that spot lever with the single spring on it is bent? the rod clearly has to be made much longer but it can't be or the spotting will be incorrect.. any suggestions?
When they get twisted they get shorter. If you can't get enough adjustment by lengthening them then they need to be straightened or replaced. As long as they are not rubbing on anything it and the machines sets pins it doesn't hurt to have a bent one on.Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
Originally posted by Pietenpol View PostWhen they get twisted they get shorter. If you can't get enough adjustment by lengthening them then they need to be straightened or replaced. As long as they are not rubbing on anything it and the machines sets pins it doesn't hurt to have a bent one on.
the spot rod needs to be lengthened but when i put it where it needs to be it messes up the stop bolt for pulling cups away..i will just lengthen it where it needs to be and see what happens.. it spots pins perfectly if i push it in where its supposed to be but under power the hook misses the spot armmrmopar
ok so i re leveled established proper height set the toe.it spots pins perfectly..however since the respot lever is bent the respot cells hesitate real bad because the cam follower comes off the cam..i will change that in the early afternoon and im sure it will button up this project..thanks guys...you all are very important people to memrmopar
So the table was out of position? Sounds like the spot ltach problem was solved.
Per the book, how big is the gap between the pawl and finger link?
If the respot cam follower is leaving the surface of the cam with the table at respot height, it could be hitting the stop bolt for the arm. On the front of the machine there are two stop bolts near the bottom and behind the spot/respot levers, near where the rods connect to the arms. If the bolt for the respot lever is out too far it can stop and hold the respot arm when the table is going down which causes the cam follower to leave the surface of the cam, which can result in loss of cell drive and a hesitation or pause in their movement when they close and open. You can turn these bolts in all the way or just remove them altogether as they are not needed anymore.
The yellow circle in the pic below shows where these bolts would be located behind the arms.
have you checked out the spot and respot lever as well as the bushings in the long 3/8 bolt through the spot latch on the top? those bolts and bushings can bend and wear giving you lots of headache.When you know what to do, everything is easy.
