Carpet belts
  • Carpet belts
    hey AMF mechanics,
    I am a Brunswick mechanic in Lower Michigan, I am looking for any of you AMF guys in Michigan that are replacing there carpet belts. If you have and didnt throw them away yet could I get them from you if they are not in that bad of shape? The reason is, I screw them to my shaker boards and the pins just slide right off the board in to the pin wheel for great pin transfer.
    What do you consider lower michigan?
      Detroit and surrounding area's
        If you are willing to drive to Grand Rapids i can save some. I just changed out a few so hopefully it may be a little bit.
          I will let you know, that is about an hour and a half from me. I appreciate the reply.
            Smurtland, what center are you at? My wife has a friend that lives in GR and she will see her on Monday. If she lives close to the center your at, she may be able to get over there tomorrow and get those belts!!
              Clique Lanes on Stocking. But when i changed out those belts i threw them out. I have some room so I can store some as i change them out. I have one I have to change out in a week or two should be good for what you need though.
