Chassis problem
  • Chassis problem
    Table contactor relay humming.changed out transformer t1,
    Spot socket where cube relay goes in.all pins are on c1-plug. Any ideas on what to check next.i will check post later .today
    82/70 mp
    pbl lifts
    wood lns
    qubica scoring&qbump
    wh/motors
    kp/navigate&defence cx4
    32 lns
    Sorry that's pin sockets r good
    82/70 mp
    pbl lifts
    wood lns
    wh/motors
    32 lns
      Is the contactor pulled in or not pulled in?
        Follow the power leads for the table contactor and make sure none are grounded where they shouln't be
        - Albert Einstein
          Is there something mechanically wrong with the contactor so its not pulling in all the way and buzzing?
            when I followed the wires from the relay to the pin sockets on the c1-plug off of a good chassis it went to different pins on bad chassis u think something is grounded. They are going to the write place.i'm using a meter..The relay is pulling In halfway.
            82/70 mp
            pbl lifts
            wood lns
            wh/motors
            32 lns
              Also did install a new relay contactor
              82/70 mp
              pbl lifts
              wood lns
              wh/motors
              32 lns
                Have you changed the cube relays with some from a working chassis? I would pop all the table wires out in the C1 and reinstall them to verify they are going to the right place and are not being pushed in when you plug it into the machine side C1. Also check C1-42H.
                  well if you are metering off the wires on a "good" chassis and the other "bad" chassis wires aren't showing continuity it could be as simple as some NO/NC wires are switched but will still work fine once the relay pulls all the way in. or your chassis could have FUBAR wiring. Lets hope its option one, cuz it worked before right? if you cant get the relay to fully engage that'd be the first thing I look at.
                    I glazed right past that - I'm assuming this is a old style Allen Bradley contactor (open contacts)? If so, a wire could be getting pinched in the armature or the contacts are interfering with the action of the relay - otherwise I can't think of any reason it would be pulling in halfway. Any possibility that you got ahold of a 82-30 DC coil relay?
                      [wb8yjf] i will check that out tommorrow.i put the new style relay in chassis.also switched cube relays around.u can manually push relay button over and table will run but when
                      u release the button it goes back halfway.0n that 82-30 dc out coil relay.iwill check that wednesday.thanks
                      82/70 mp
                      pbl lifts
                      wood lns
                      wh/motors
                      32 lns
                        i know the problem is in chassis,no matter which machine i put it on it does the samething.i will check out what grit posted also..this chassis did work at one time..thew first problem i had with this chassis.billy was working with me .chassis sometimes would not spot pins that is the reason why i replaced t1 transformer an spot cube socket..now i have this problem.i just
                        dont want to bother billy ..he is good .this is one of my 3 spare chassis..i just would like to slove this problem.thank yall again guys.
                        82/70 mp
                        pbl lifts
                        wood lns
                        wh/motors
                        32 lns
                          Could be you just have a bad 'new' contactor - it happens, rarely, but it does happen at times.
                            If you have a 24v power source, (18 volt cordless drill battery will work) you can check the relay to see if it works correctly. Make sure you disconnect the power wires going to the relay before you connect the secondary power source.
                            Is it humming or vibrating?
                            - Albert Einstein
                              i just dont want to bother billy
                              Bother away! Seriously though, that's what I'm here for. If you think I can help, by all means give me a call.
                              Regards,
                              Billy T
                              bthompson@qubicaamf.us
