help asap please
  • help asap please
    lane 15 i can not get my pit to turn off the machine blacks out but the pit keeps running i am lost lol tried just about eveything i know 8270 solid state chassi with omega exspander boards accu score xl scoring please help me out thanks
    Kick the chassis and it should stop. The back end motor relay is stuck/welded shut. Clean the contacts or replace if real bad.
      i changed chassi and still same issue
        If you hit the chassis does the motor shut off? It is very easy to have the relay stick on more than one.
          no it it dont like i said i put a brand new chassi on and still same problem
            What kind of chassis?
              solid state chassi omega tech exspander boards
                Check EE and W on the top row machine side
                  Have you worked on this lane/c1 plug? If not check under the chassis and see if anything has fallen on the terminal connections. To check if it is the chassis or machine, unplug the machine and the c1 and then replug the machine.
                    If 16 is running you have a bad ball lift clutch - it is locked up causing the other lane to run
                      I agree with this (ball lift clutch on 15 is seized) and if it stops when you turn off 16 well then....
                        well that worked thanks man i had one of the pin indications off thanks
                          you guys were way off its obvious it was a chassi issue lol
                            Careful....
                              Yeah it was obviously a chassis issue, but to make a statement like that would hardly encourage anyone from offering help in the future. Keep in mind, though, some things while obvious, have an underlying cause that isn't so obvious...hence the reason many come here seeking help.
