Interesting issue with my problem child machine
Lucky number 13 is at it again. I walked in this morning to prep for the youth league when I noticed the sweep down on 13. I say to myself no problem, the night pinny was probably sent home early and the front desk just moved a pileup. I get to the back, no note on the call sheet so I go and turn the machine on and nothing happens. No problem, lucky 13 has a tendency to trip the breaker about once a month so I reset it and it immediately trips again. Hmm, a new development so I pull the RS plug and again reset the breaker and it holds. I look at the chassis and notice the A/B sweep contactor is not looking like it should so I yank the chassis, replace the fried points and hooked everything back up. Plugged the power back in and the sweep motor hums. I pull the plug from the motor and the hum stops. By now its been maybe 2 minutes since applying main power and I notice the front wireway is radiating heat. I pull the plug, remove the cover and find CSM2 has exploded. I clean up the mess, remove the blown cap, test the other 3 just to be sure, replace the bad one and put the cover back on. I plug main power back in with the sweep motor not plugged in and I notice the sweep contactor engages as if the sweep were triggered. I plug in the swp motor and it hums again. As I was in the process of moving the table plug over to the sweep motor to test it I see smoke starting to billow out of the wireway where the caps are. I pull main power and quickly remove the cover. The entire cap area is full of smoke.Great, another electrical issue.
Tags: None
[QUOTE=cdsand5;493062 I plug in the swp motor and it hums again. As I was in the process of moving the table plug over to the sweep motor to test it I see smoke starting to billow out of the wireway where the caps are. I pull main power and quickly remove the cover. The entire cap area is full of smoke.Great, another electrical issue.[/QUOTE]
I had one on Thursday. Killed all power to the motors to grease front end and table. plugged everything back in and as soon as I hit the switches on the control box the chassis went up in flames. Literally, flames almost 6 inches out the top and little fire balls dropping out the bottom. Killed the power and found a butt connector on the be motor circuit caught fire and melted 2 other wires.
Hopefully your problem is as easy to find as mine was.Sometimes we have to do stuff to get by....Just go back and do it right when the "by" has passed!!
