I did have a large towel in the machine catching all the sparks but didnt have anything between the machines. Stopped grinding and could see smoke. Luckily I had a cup of water with me so it got put out quick. went and got another wet towel to put in there.
rear roller mount
rear roller mount
The half moon mount on the bds busted out. First one that i have had to do, they are not fun. Pulling pit, plow, drilling new holes, grinding old mount off, putting out a fire, bolt new mount on.
I did have a large towel in the machine catching all the sparks but didnt have anything between the machines. Stopped grinding and could see smoke. Luckily I had a cup of water with me so it got put out quick. went and got another wet towel to put in there.Sometimes we have to do stuff to get by....Just go back and do it right when the "by" has passed!!Tags: None
Yep, can be an extreme PITA on the rare occasion when they break - sounds like you've got it covered bolting it back in (high tensile bolts all the way!). At least you now know that particular half-moon will last!!
They changed that on a 90 to a bolt on part. Obviously due to this happening. I got into a habit of every pit I pulled I changed them to bolt on. Much easier to drill the holes in the right place with it still in one piece.
Originally posted by 8270king View PostI have beat the old one back into place and bolted the new one over it for extra strength
Never understood why, as well as some other parts that will eventually fail, were welded on the machine. I can usually do one of these without pulling the pit, just get rid of the rear roller and small plow and you can get in there with the grinder and drill.
I think the best part was the rear roller was only a couple months old. just about cut the shaft in half.Sometimes we have to do stuff to get by....Just go back and do it right when the "by" has passed!!
Originally posted by smurtland View PostI did have a large towel in the machine catching all the sparks but didnt have anything between the machines. Stopped grinding and could see smoke. Luckily I had a cup of water with me so it got put out quick. went and got another wet towel to put in there.AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Originally posted by Pin_Head View PostThat's why I always highly recommend to anyone that prior to doing this job you thoroughly vacuum the entire area, under carpet area, between kickbacks all the way from the back up to the tail plank. Was your towel heavily soaked in water? That's what I do in areas that will collect sparks, when I use a towle etc I douse it heavily in the good old H2O.....
