options ball return
  • options ball return
    power going to board but nothing happens checked all fuses changed board nothing.
    Used extension cord plugged motor in plug outlet ran why is there nothing to control box.
    Could there be a faulty interlock switch? Not familiar with Options so that's just a guess.
    "Party on dude!"
      tried the forced on forced off all that stuff with the buttons nothin works.
        Got it direct wired now motor hand dryer to power coming in it will just have to run 24/7 until
        I figure why it won't work when I hook the board up to it tried 3 boards nothin.Lge comin in in an hr gotta oil yet
        any help thanks
        Scott
          any help thanks
          Scott
          Did you try a board that is already working OK? Where did the other 3 boards come from?
            BRANDY NEW FROM ANONTHER MOTHER F#$%^&& JUST RECD. OVER SUMMER
              could the cord from the machines have been run over on the ball track so your not getting a signal?
              Also try a board from another pair that is currently working.
                Need to verify to on signal is getting there from the machines.
                  This will have to wait til morning now lge. startin at least it's runnin with direct power.
                    Just sent you a PM.
                      The triac next to the board (with the 3 wires) does fail. that device turns on the motor via the control circuit on the board. jumping the 2 bottom wires on the triac will tell you the wiring is intact and the motor should run.
                      The 70 just shorts out the #1 and#2 terminal on the top. So to test the machine circuits from the A&MC, just jump those terminals with a 3" piece of wire.
                        Ted- don't think he's got a 1215 board w/ triacs as he said he tried forced on mode. I don't understand how it won't work in forced on unless as previously mentioned the interlock switch has a problem. Jump out the interlock switch terminal connections to confirm.
                        Regards,
                        Billy T
                        [email protected]
                          Like what's been said, with power off check continuity on interlock circuit with a meter. Maybe take the board out and have a look at the rear. I've had a few over the years when the track on the board has been broken. You could check continuity on the board with a meter.
                            Saftey switch shorting out?
                              If the options ball return works different than a C90 ignore this...but when my C90 interlock switch flipped the fan still works it just shuts down the lift motor.
                              70's MP/PBL/LBS,Q-Score
                              Prolane Walker sport
