Roller clutch
  • Roller clutch
    Does anyone have a picture of the roller clutch as I cant find one on here? And what are peoples thoughts on it?
      I really liked them. I got them from Bowltech (Complete Leisure, not this site!). They were a little sensitive getting set right but once they were on and coupled with the solid trip rod (instead of wire) and the lube free pinion gear from Bowling Vision I had super smooth indexing and one less part to need lubricating.
        Thanks for the feed back. Have you tried the new style clutch from embassy? I think they are really good, make a few noises but run well.
          My last centre had all 22 lanes of the Embassy clutch (drum style). They were ok, squeaked a bit and left some dust (although you can now get a leather pad to replace the original pad that creates the dust). The spring also would stretch with time, but again, you could buy replacements or fit 2 of them. I preferred the roller clutch though as you could still adjust it like the original. Bowling Vision also stock the drum clutch as well as the spares for it.
            Roller clutch > all other clutches
            Tried them all
            Easy indexing and allows enough tension so there are no issues with the dist. running from the 6 to 10 position
              Tried them all
              I second this motion
