BE Motor (westing house) Stopping HELP!!
  • BE Motor (westing house) Stopping HELP!!
    Hey Guys,
    We have a back end That is stopping after about 30 seconds of run time. we took Out the Back Gear and The side Gear and it still Stops. We Replaced the Rotor and We Replaced the IB Bearing And Seal (we do not have a Bearing Assembly Plug to help properly Gage Bearing Could this be the Problem?
    Also on a Side note, Can anyone Tell me Where they are getting there Rebuilds for these motors/ or new/used ones just got a new price from our supplier 070007903-R-LH Motor Gearbox 60HZ Rebuild $1392.34 + Freight + Tax (Mind blown)
    Tony S
    Splitsville Entertainment
    82-70 Machines
    Brunswick Frameworx scoring
    Change Chassis / Check Pins
    Change thermal overload button
      Is your issue electrical or mechanical
      Is the gearbox locking up after it gets hot?
        Whenever I had this problem it was the stator overheating and kicking out the klixon, but none of ours ran for half an hour, I don't think. If it does this consistently, though, you might replace the klixon to rule it out.
        Toby
        82-70B, Stepper chassis
        www.mooseexchange.org
          Hey guys i might have messed up on my Wording a bit.
          The Motor is On the Work Bench not On the Machine.
          So no Chassis pins To Check it is in the Motor itself its not over Heating its more Binding Up ON something . That is why i thought maybe could be the IB bearing
          Tony S
          82-70 Machines
            Stahl's rebuilds motors National, GE & Westinghouse. Just have to send them your motor before they repair and exchange.
              Is your Dist. housing running tru?
              Cent Sw or Rotating Sw?
              Try another Head?
              http://www.brainstormis.com/library.php Might have a used one for $400-$500
                If is sounds like it is grinding it could be one of two possibilities. One like you have stated the bearing cup is worn beyond repair on either side or both. Second the start switch is not cutting out at the proper time, thus it is trying to run at two different speeds.
                  I've had them after rebuilding, take a plastic or rubber hammer and bang the rotor end bearing ( stator off) up/down/left and right. It will loosen and set the brass bushing. It sounds like it binds after a few seconds and heat up.
                    Exchange & Repair
                    www.jcpbowling.com
