Chassis issue 82/70- ss
I have a chassis here that works perfect...except when it engages the table for the spot cycle, it does not send the power to the spot solenoid engaging that whole assembly. It acts as if it does send power because the table still goes down but only to respot height due to the not engaging of the solenoid. Any tips? Alrdy swapped omnitek boards, spot relay, and t2 transformer (had a hunch). Any help is appreciated. ThanksHumpbacks..Qubica..AMF 82-70..what more can you ask for?Tags: None
Check the pins on the C1. Also, the spot socket may be going bad - if the pins are OK, then grab ahold of the spot relay when it's supposed to be spotting and give it a slight twist - if it suddenly works, chances are the socket is bad.I've had enough of hope & chains.
Originally posted by wb8yjf View PostCheck the pins on the C1. Also, the spot socket may be going bad - if the pins are OK, then grab ahold of the spot relay when it's supposed to be spotting and give it a slight twist - if it suddenly works, chances are the socket is bad.
If this is a solid state chassis with omega teks then make sure the little jumper board is in there and facing the correct way (did somebody touch this chassis right before this started happening) If this board is backwards or missing the spot solenoid will not work.
Originally posted by racelanes View PostI had this problem last week! Mine was a bad lower table contact might want to get a meter on it just to check.
Beat me to it, I was gonna suggest the jumper too TJ. Seen that one before and that's EXACTLY what it'll do. If not that I'd for sure check the SP socket and wiringAll I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
