Never had to order the stuff on the AMF side before. Thanks!
Up Rail covers
Up Rail covers
hey all. I have a lot of bad up rail covers and was looking for a good manufacturer to use for replacement covers.. I've heard of guys using brunswick cover before with great results. Also please include if a thimble is needed.
Never had to order the stuff on the AMF side before. Thanks!Tags: None
I've neen using the red covers from CNC on the lower portion of the rail with great success. One cover will do a pair of lanes. Just cut it in half. I then use the standard black AMF cover for the upper portion. It's alot cheaper than the clear covers from AMF and does a great job. Using a thimble isnt neccessary but it will help the bottom edge last a little longer.Give me a hammer and some duct tape and I can fix it!
Stahl's thick tan covers with the orange thimbles..... WIN!
We never, EVER have balls yo-yo-ing on these......EVER!!!
When using these with a PBL the orange thimbles are a must as the covers are thicker and the tapered thimble matches the diameter of the cover, allowing a smooth transition from the lift arm to the lift rods and as Kat stated they keep the ends from getting torn up. Without them the ends will tear and the balls will have some difficulty leaving the lift arm. We have some that have been in the machines for 15+ years, really, they look worn but they work perfectly. In fact, after 5-10 years lets say, you just turn them a little to expose an untouched part of the cover and they are as good as new. And, they slip onto the rods easily too!
I use Brunswick covers. But they match the diameter of the thinner covers. If you use the thimbles and are replacing fat covers, I wouldn't use Brunswick covers. I also still have kickersGiving bowlers less to complain about, one lane at a time
