Table Eccentric Rebuild
Hi all, I recently replaced a table drive eccentric because I noticed the drive was slipping when you would crank the table manually. The cone bearings inside the old drive are shot. My question is how to you replace the large cone bearing inside the eccentric drive? There doesn't seem to be any room to get a bearing puller to grab and I'm a little stuck on how to remove it so we can put a new one on to finish the rebuild. Any advice on how some of you have done this? Thanks very much in advance for your time and input.
