Part # for underlane "flapper"
  • Part # for underlane "flapper"
    Need # for the part that mounts in the underlane near the foul line and keeps balls from rolling backwards if front ball return fails to pick up ball.
    Triangle thingy with a hole in one corner
    Thanks
    Go Pirates
    For just the stop the part # is: 135 001 002. For the whole kit the # is: 611 353 105.
    I had them in a center I used to work at, and when one broke I just made a new one out of some old lane edge board material I had around.
      Same here, old plastic 1" flat gutter bottom piece and a couple L-brackets from the hardware store. (use a 5/16" hardened bolt, the 1/4 inch don't hold up over time)
