Part number help for pbl
  • Part number help for pbl
    Looking for the part number for the upper shaft. I want the one with threaded ends. The number I use iI get a shaft with reaining rings on the ends, they are a little to sloppy for my liking.
    Sounds like you are describing the 'old style' upper shaft (retaining rings) that used the locking collar bearings installed from the outside- astonishingly I still have a few of these running and who knows how old they are.
    You can replace this with either the round shaft or the D bore one, plus the appropriate bearings (that install from the inside) and the spacers and nuts.
    Kit #610-900-711 includes all these parts (minus the nuts) with the straight/round shaft. I don't have the part#s for the individual round shaft parts as we like to use the D bore.
    Individually....(D bore)
    D bore shaft upper-070-011-795
    D bearing-070-011-797
    Spacer-070-006-748
    Flange nut-856-070-002
      070-006-699 Bearing
      070-006-747 Upper shaft new style
        Stahls, is that for the straight shaft?
          Yes it is.
