Roller Assembly
  • Roller Assembly
    Roller assembly
    What you guys think about this? What is the side effect for the carpet belt?
    Last edited by arthur3117; 03-05-2013, 07:47 AM. Reason: Want to know is the washer will scratch the carpet ?
    Hi everyone, due to save cost I decide to add on washer. Is there any other alternative? Pls advice and thank you
      I would expect that to destroy a carpet fairly quickly.
      Regards,
      Billy T
      [email protected]
        100% not acceptable
        Buy a new roller body and fix it correctly
          Originally posted by 8270king View Post
          100% not acceptable
          In this case it"ll end up costing you more in the near future.
            Scrap metal, with washers on it. Rollers are a pita and costly , butt no where near as costly ad replacing the carpet weekly .
            Change the chassis, is not the answer.
              I wouldnt expect the carpet belt to last more than a few weeks at best... so factor the cost of replacing your carpet belt monthly. adds up quick
                Yeah, I probably would not do that. The roller body needs to be smooth, if you add something like that that protrudes it will damage and quickly wear out the carpet belt- similar to when a front roller screw becomes loose and sticks out of the body putting holes on the part of the carpet, except this could be worse.
                Sorry, A for effort but it's just not something you want to do.
                I'm guessing you did this because the holes in the body wore out so the screws would not keep it tight, and this was to re-use this part to save money. nothing wrong with trying to get more life out of a part and while the body is not cheap really this will end up costing more as it will ruin another part- the carpet belt, which is also not cheap. Think of it this way, the roller body was designed this way for a reason, with tapered screws that fit into tapered holes so they are flush with the body, and that is to prevent damage to the carpet belt and keep the body tight. If you add something to it that protrudes it will damage the carpet.
                So by ordering a replacement body for this while it may not seem like it at the time, you will actually end up saving money by not damaging carpets with it.
                  OUCH
                  I'd weld around the hole and retaper the hole with a drill before I'd try that. Ummmmm NOT that I EVER had to do that or anything
                    Originally posted by old-school-mechanic View Post
                    OUCH
                    And I've never had to hang a broken cushion weld with a truck tie down to keep it going through league....lol
                    At least this way you could make it flush with the roller body- as long as there was no way it could damage the carpet but still keep the body tight.
                      I agree with everyone that the "right" way to fix it is to buy a new assembly, but if a center is struggling badly financially and cannot afford to buy one, what are some acceptable ways to get more miles out of a part like this? Someone has suggested filling the hole with weld and redrilling. What else can you do?
                      Toby
                      82-70B, Stepper chassis
                      www.mooseexchange.org
                        Toby
                        If you need to get this part back in the machine due to financial reasons - lock the doors and declare bankruptcy
                        There is no way to salvage this roller body
                        It has been said many times above - it will cost you more to put it back in - even if you weld and grind the allen screws
                        Disassemble and fix correctly
                          Thanks to all of you for your kind comment。of cause i would like to change, but the centre business is not so good. currently i can get usd 48.30 per unit, and now I do need 14unit. Anyone of you can get better price than this?
                            HEY
                            Now I only had that tie down on there for 2 days. I did get arounf to fixing it !!!!
                              HEY
                              Lol...
                              Oh, you too! The red one, right?
