Thanks!!!
82-70 Cent. Mech. to Solid State conversion on sweep
I am converting a sweep over to a solid state from the old centrifugal mechanisms. I have done many of these on tables, but i know there is a specific way to wire these up to regain sweep reverse. I dont have a diagram on hand so i was hoping someone here could help me out with some kind of wiring diagram or how-to. Im running Westinghouse motors with Solid State MP Chassis and im using the gray Solid State Switch from Qubica.
Thanks!!!Tags: None
Wiring diagram is here http://www.cybernetic.com.au/diagram...revMP85alt.pdf
The rest for reference are on this page
It's not as tricky as the diagram makes it look
As an additional point. When you have done the wiring modification it WILL also work still with centrifugal mechanisms. So if you have a sweep motor go, and your spare doesn't have a solid state switch it will still run fine.
So you can mark up the machines which have had the wiring modification, and if you're fitting solid states in batches, then there's nothing to stop you going ahead and wiring all the others ready for your next order of switches
I have issues with the bowl tronics switches on sweep motors and back end motors. I think they dont like heat very much. The back end ones work, until you try to turn on the motor while its hot (westinghouse or GE), they instantly overload and when you do get them to start, you gotta pull start em.
sweep motors just like to overload and interlock at random timesGiving bowlers less to complain about, one lane at a time
