dead chassis
dead chassis
ok i have this problem with my spare chassis. Its got an M/P board in it. the problem is that it won't do anything. All that happens is the pit light goes on. all of the contacts(sweep,table,B.E.) work by pressing them manually. I tried changing the board, the T1, all the realys (all realy plugs are good too) changed the smaller transformers. I swapped the parts with new ones, so they should be all good. All of the amp plugs are good. everything seems to be wired up O.K. Well, I know there are a lot of veterans out there, and I hope u can give me a few good ideas. thanksTags: None
Re: dead chassis
Did you check all the pins in the C1 and C2 plugs. If one of those is burnt or push in, you won't get any machine function at all. I had this problem with a chassis be for, and there was a burnt pin in the C1 plug. Give this a try and let me know if it works.Give me a hammer and some duct tape and I can fix it!
Member
- Aug 1999
- 2547
- A-2s, GS-X, 82/70-90
- Brunswick Vector Plus HD
- Brunswick Envoy
- Pro-Anvil
- 1985
Re: dead chassis
Tricky...
Is this chassis a true MP or a wanna-be MP(converted SS)?
If it is a true MP, what happens when you hit the Program Zero button on the side of the chassis? If that doesn't work, make sure your pinsetter is at complete electrical zero before zeroing machine. Let us know which type of chassis it is and we'll go from there.
Best of luck!
Kat"Where are we going, and why are we in a hand basket?"
Re: dead chassis
Absolutley nothing happpens when I press the zero sitch on the side. This is a true M/p with no conversions at all. This thing has really got me stumped. Plus it is my only spare in a 40 lane house so I want to fix it as soon as possible. Please keep trying posting these good replies. thankx
Re: dead chassis
will the table and sweep run using the cam levers?If so it might be a cycle problem.
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
Re: dead chassis
Have you tried (I'm sure you have, but thought I bring it up anyway) taking a known working MP board from another Chassis?
Also, which model boards are you using?
9850? 9860? or 9861?
If the board is known good, double check your CBs (1-4) on the side of the chassis. Check for continuity on each CB.
Also swap known working relays (M1, M2, & S). Be careful with the S relay, as all relays are 24VAC. On the older SS (or wanna-be MPs) the S relay is 10VDC. Common problem in centers with both types of chassis mixing and matching relays in the wrong sockets. Let me know if this helps!
Re: dead chassis
Check the fuses if you have them. I had a similar problem, pit light worked but no motor function. Checked everything but nothing worked. I checked that little 2.5 amp fuse and that was it.
Good Luck Knuckles
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
