If the machine is on first ball and I press the cycle button, the sweep drops, table feels for pins, takes them up, sweep takes away dead wood, then when the table gets to the top with the pins in the fingers, the machine goes into strike cycle and trys to set a full rack on top of the pins that are already in the fingers. As you can imagine this results in some very nasty things.
I'm lost. I can't understand where the machine is getting strike cycle info from. If the bowler throws a ball all is fine, but not from the mechanics panel. Also does the same thing from the bowlers console. Pin falls over during spotting, rerack left lane, big mess. Push the reset button and all is well.
help.
keeks.
