[ November 06, 2001: Message edited by: geminix ]
Machine Cycle
Machine Cycle
I have a solid state chassis with Omega-Tek boards (MK-70 & expander). When this chassis is on a machine it cycles great when a ball is thrown and activates the cushion MS. However it will NOT cycle if you press the cycle button in the rear control box.
[ November 06, 2001: Message edited by: geminix ]Tags: None
Members
- Aug 1999
- 2307
- AMF 82-70 SS Nat PBL Hump
- Qubica/XIIX
- Walker/SanctionSE/PhX
- ProLane/SPL
- 1982
Re: Machine Cycle
does the RPO button up-front work?..non-scoring button on the scoring panel?...but it probably cycles when you hit the tenth-frame switch....the one on the sure-pik [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
if this sounds like your problem the probs in the mask/APS plug on the 10pin side of the chassis.
Re: Machine Cycle
The problem sound like either the
EMC or EXP board in the scoring
chassis.
Double check your installation of
the scoring to see how they installed
them.
We have accuscore II in our center.
The cycle button (back panel)is part
of the RPO circuit in the curtain-wall chassis. Replacement of the EMC board
cured the problem in our center.
doc [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
Re: Machine Cycle
Which Accuscore do you have? If Plus, the only thing I can think of is the wiring between the machine cable from the CWC to the back end control box, especially if RPO works OK from the bowlers terminal (<RERACK> <ENTER>).
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Re: Machine Cycle
Check out your pins and sockets in c1 and c2. One is likely to be pushed in in the c2 (low voltage)
king
Re: Machine Cycle
Coors, you got it. Thanks buddy. It was a severely bent pin on the PM plug. I repaired it and I am now getting RPO cycle. It's weird that this function goes thru the PM plug but, hey, now I know for future reference. Thanks again!
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
