I love the ball return itself. (anything beats surepicks) I just can't keep a hand drier motor/fan. I've gone thru a least a dozen in just a couple of years. They were just little square box looking things. Then AMF came out with a different contraption which works only a little longer than the others. They just plain fall apart. Anyone come up with something else?
C-90 ball return question
Re: C-90 ball return question
I've had c-90 ball returns for 6 yrs now and have not had to change any so far, just lucky i guess. we clean them every month,maybe that helps. resin balls are are tearing up my wheels though, started useing brunswick tires &they work much better
danno
Tech running constantly???? I'm running about 55 lines per lane per day. That's pretty constant in my book. If you mean overnight. They don't. Also they are cleaned. Although I havent found a really good cleaner for the plastic hood.
Please! Please! send that Grainger part# for the fans you use.
Grainger has them, so does DigiKey (little higher in price).
Note on the Fans- Make sure you get
the Ball Bearing type.
Sleave one will seaze up about about a month
of use.
The Ball bearing ones are rebuildable providing you ahve a source for the micro bearings (hae not found a source yet)
Doc
