Anyone else having this problem?
Am I the only guy with hardware problems?
Seems that lately(past year) all the problems in my center are due to hareware(nuts/bolts) failure. Is the quality these days that bad? I'm replacing bolts that I just installed a year ago or less. I understand that cushions and bounce plate supports take quite a beating but wow this is getting old fast.
Anyone else having this problem?Tags: None
Re: Am I the only guy with hardware problems?
fix it
I just ment that using a locknut such as a nylock say on your bounce board brackets tend to come loose alot faster than the flexlocks you may buy from a distributor and if the nut is loose the bolt will have undo presure on it causing it to break sooner.
Thanks ChuckCHUCK MCDOWELL
Always use stover lock nuts from AMF, ,nylock will not handle the vibrations of bowling. Nylock means plastic and when a little oil gets in them they will work loose. ALWAYS USE STOVER NUTS!!!
