82-8 foul light replacement
Members
- Aug 1999
- 2307
- AMF 82-70 SS Nat PBL Hump
- Qubica/XIIX
- Walker/SanctionSE/PhX
- ProLane/SPL
- 1982
Re: 82-8 foul light replacement
i myself use Bowltronic owner always promises me a few Zot conversions....but never comes through...i dont know if 82-8'are the same as 82-120's or not....any how bowl tronic is good....click on the "pinsetterparts.com" ad on the top of everyother screen to get prices
I've had 82-8"s for forty years. Ed Marshall converted the wall boxes to solid state about five years ago. We replace about twenty 1154 bulbs a month, but they still keep on ticking. ( 48 lanes ) A new foul light system has been ordered, but I don't know what type. Summer project-I hope!"Gun control is the policy of tyrants"
Rep. Rob Bishop (R-UT)
I've installed 24 of AMF's infra-red foul light unit. If you are relacing 82-8's you will have to cut your capping and run power and lamp cord wire to foul line.They fit exactly like 82-120's.The only problems have been with the terminal blocks and afew transformers had a leg break off. In both cases the foul light would foul when stepping on the line but it wouldn't send voltage to machine to trigger foul cycle. The terminal block can be fixed by running a jumper wire.The transformer has to be relaced.It is soldered to the board.Could be a little hard to find transformer. It is much better than the 8's or 120's.I hardley even know they are there.That is unless they kick the common housing off the floor.What can you say, BOWLERS.
Quote:]Originally posted by amfpinboy:
I've had 82-8"s for forty years. Ed Marshall converted the wall boxes to solid state about five years ago. We replace about twenty 1154 bulbs a month, but they still keep on ticking. ( 48 lanes ) A new foul light system has been ordered, but I don't know what type. Summer project-I hope![/QUOTE]
48 Lanes in NJ you wouldn't be at WALLington would you?
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
