I know that the GS machines have a free hanging curtain and was wandering if anyone had tried it with AMF machines.
pin curtain
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
pin curtain
Just wandering if anyone had there pit curtains unhooked from the cushion and if it caused any poblems. We are having alot of pins standing in curtain causing mis-scoring.
I know that the GS machines have a free hanging curtain and was wandering if anyone had tried it with AMF machines.PeanutTags: None
Re: pin curtain
The only problem I could see with doing that is the curtain would be too long. It would probably drag on the carpet belt. I like the idea though. I might try it.Give me a hammer and some duct tape and I can fix it!
Members
- Aug 1999
- 2307
- AMF 82-70 SS Nat PBL Hump
- Qubica/XIIX
- Walker/SanctionSE/PhX
- ProLane/SPL
- 1982
Re: pin curtain
the only problem would be....
the curtain would be hanging down not more than 1 inch or so from the pindeck...against ABC regs.
unless your talking about hanging the curtain from the middle of the machine where the L-beam is...but then youll have "Larry Launch" causin pins to wack the distributor or get into the ball return area...i have been lazy and just left the curtain hung over the cushion and youd be amazed where pins end up...lol
Members
- Aug 1999
- 2307
- Qubica/XIIX
- ProLane/SPL
- 1982
Re: pin curtain
i take that back....the pin curtain would be hanging 6-9 inches from the back of the pin deck...not more than 1 inch from the end of the table....lol
Re: pin curtain
Not only would it look bad from the front,But if you have ever been hit by a flying pin that was launched out of a machine you would learn that it is not a good practice to leave them down.
Re: pin curtain
Sorry,I missread the post. I have seen curtains that hang from the rod and were not attatched to the cushion. They did have some that were tore up a little and I could see where flying pins could still be a little dangerous.
Re: pin curtain
hey masternut, if you are refering to the pins getting stuck between the machine side frame and the pin curtain where it likes to stay so the camera's can see them, try this, get some pin coat and thinner from your distributor and coat your pin curtains to make them stiffer. i have done it and it works great. also word of warning keep your hard pads on the cushion weldment to protect the pin curtain from hitting the weldment and putting holes in them. the mechanic before me removed them all and when i got there 39 of my 48 had holes in them that i had to patch up and had to replace some and they are not cheap !!!!
jimjim k.
Members
- Aug 1999
- 2307
- Qubica/XIIX
- ProLane/SPL
- 1982
Re: pin curtain
i cannot exactly quote the exact reg...however now ill investigate.....but there is a reg about having a "rear plank" no less than x inches away from the back of the pindeck...a curtain may not count as a "plank"(or what ever the term is)...but it would definately be a gray area.....especially with 7-10 conversions with curtains hanging no more than a foot from the back of the pindeck
[This message has been edited by Coors (edited 04-20-2000).]
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
