Has anyone had to remove the plastic ring in the back side of the plate in order to achieve good indexing? I now have 2 roller clutches without the backing rings in service. Either the stop blade caught the ring and got stuck, or you couldn't find a good blade adjustment so the roller could pass thru the blade.
Anyone else have that problem? Since I took them off they are fine. I use 5" pulleys on the gearbox.
I did struggle at first getting them to work perfectly, I have noticed that with the blades as low as I can get them and still clear that ring, the roller just touches the bottom blade as it passes under, but hasn't really caused any issue. In saying that it has caused the edge of the rollers to wear down slightly..
Still though, if you've taken them off and they run great then wonderful, if you have great pin spacing then the nylon ring isn't really needed anyway.
Of the 2 we installed I noticed this too, the roller barely clears the stop blade and on one of them it was tricky getting it set right. I just chalked that up to an old distributor but if the collar was a little thinner or the bottom stop blade was a tad shorter or had a notch in it the roller could pass more easily imo.
I ground down the stop blade where it is common to touch the pinion. It let me set the blade lower, still clearing the pinion teeth, and giving the roller more room to pass thru the blades. And the nylon ring removed.
Let me know, and I will leave them off of yours. -Mike @ Stahls
I have one roller clutch and I have white dust all over from the blade rubbing on the ring. The blades are as far away as I can get them and get it to work. I also second the welding, everyone I have I JB weld anyway.
I have removed all of the rings on my clutch plates, and its never been a problem. With 5" pulleys on the BE motor the spacing is just fine so as not to bring the ring into play.
I just installed 1 and had the problem of the stop blade rubbing. Heard this squeal kind of noise thought what the heck I added another washer on the shaft where the pinion pushes up against to bring clutch farther out and works fine now.
I have been running super clutches with homeade rollers. I just used the steel cam followers because they don't wear like plastic and I cut and re welded all my stop blades to make perfect clearence. They work fantastic.
That's impressive..... I think the enviro type material will be far superior to the nylon roller... Awesome clutch btw, I'd NEVER bag out the roller clutch I'm a huge fan. Just found 12 months on starting to have a few sticking issues as the rollers wear. So far excellent results with the cam follower, just had to tinker to learn the best set up for them....
I am removing all the white rings - they do not clearance the stop blade often enough.
