back end mtrs
  • back end mtrs
    does anybody have any mtrs for sale 8270 national .what happened to the franklin mtr that was on the market did it dissapear
    Re: back end mtrs
    Call Hilltop Bowling - 937.882.6605
    they have plenty of used 70 parts.
    They will ship them right to you.
    king
      Re: back end mtrs
      The Part Number for the Franklin Motor is 785-502-259. I just got 2 of them in. Hope this helps
      Terry
        Re: back end mtrs
        terry from where and for how much back end mtrs
          Re: back end mtrs
          I buy them from AMF. I beleive the list price is $360 for the B/E. I don't beleive they handle the Combination Motor because at one time they were having trouble with the Motor drifting, but I am not positive.
          Terry
            Re: back end mtrs
            Quality sells a Leeson combo motor. We are running several of them. There’s very little difference between them & the Nationals that you’re used to. Off hand, I don’t know the part # or the $.
            Dutch
              Re: back end mtrs
              I believe AMF no longer sells the Franklin motors from what I understand. I think they're garbage anyway. Just try getting replacement parts for them. I use the Leeson motors from Quality as well. They are a good replacement motor and you can get them in a combo or BE. I do have a question about the Leeson Combo motors though. I have an older style combo motor that does not have a brake and it simply relies on the gearbox/lower contacts/switch to stop it and it drifts badly. Do they make a brake kit for these motors? The newer Leesons already have these brakes but I am not sure if they have kits for the older ones or if anybody else has encountered this problem. Thanks!
              Bob
                Re: back end mtrs
                Yes, they do make brake kits for Leeson combos. Check with your distributor for the # & $.
                Dutch
                  Re: back end mtrs
                  I dont understand why your local motor repair cant fix (rewind or rework your armature). i have westinghouse. Ive herd tell that vantage B E motor does not have as much winding and would cause it to run louder. As for a combo motor you would need to supply the repair shop with away of turning them on there work bench. I have such a control box.
                    Re: back end mtrs
                    does hilltop bowling have an email address?
                    chasing g/e stators backend
