C-1 plug diagram
C-1 plug diagram
C-1 plug looking at chassis left to right across 1-blank 2-input power 3-B.E.main winding 4-B.E.winding 5-pit light 6-blank 7-input power 8-input power second row left to right across 1-blank 2-blank 3-blank 4-spot solenoid 5-respot solenoid 6-neutral 7-table motor break 8-table motor break 9-table motor main winding(TMP-X) third row across 1-blank 2-sweep motor winding(SMP-Y) 3-sweep motor start winding(SMP-Z) 4-blank 5-sweep motor break 6-sweep motor break 7-sweep motor main winding(SMP-X) 8-neutral 4th row across 1-system ground 2-sweep reverse switch 3-sweep reverse switch 4-neutral 5-blank 6-blank 7-neutral 8-blank 9-blank hope this helps pindecked signed felixIf at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.FieldsTags: None
