masking unit
masking unit
have painted my mod IV with glo paint and they look great. problem is my parchment paper is about shot,where can i find?If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.FieldsTags: None
Re: masking unit
Felix,
I tried very hard to get parchment for our old ones. We just put in C-90. A printer in our area said he could do them but it would be expensive.
ALSO THANKS FOR THE WIRING ON THE CHASSIS PLUGS.
king
Re: masking unit
Several of the parchments in our modV pinvisor MAGIC TRIANGLES are falling apart also. AMF is apathetic and refuses to produce more. For several years we have just hot glued the shredded tatters together but it is just a "band aid" and every time you take them apart the plastic gets a little weaker.
My boss thinks that you could find thin enough paper somewhere, set some bar glasses where the lights go and tape where the foul & strike lights go, spray it black, stick some stick-on numbers in and there you go. I think this would look very amateur and not work very well.
As for pin light holders, we have fashioned some out of thin sheets of aluminum (even cutting up a pop can would probably work)and putting it around the socket so that the aluminum strips stick out about 1" wider than the holes to create enough tension to hold them in. Eh...
As for me, I think I could go for some good "Magic Triangle" about now, but the owners of the magic triangles usually disagree unless they are fat, ugly and mental. You gotta do what you gotta do...
Yer Pal,
Chad Q.
