have put a "tuffy" pin orientator on my problem child,#070-006-144-TPO; no problems last two weeks now!
dist.
Re: dist.
I mentioned this in another thread, IVE seen this part and it kicks butt for the 30, and 70's! It helps out with weak dist. belts and with the never ending change of old pins to new pins! Hey 70 guys, use this product and use a PW drive pulley that is half an inch smaller and life gets alot easier!
Ed
PS: It's a Stahl's product (wich I think should help support this site! Stahls that is!)
------------------Please buy MADE IN USA!
Re: dist.
how do i get my picture to this reply page with a scanner and or fax?If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Re: dist.
felix,
I might suggest you do as I did. Send the pic as an attached file to Mike Wilson. Include some text describing what it is, what it's for ect.
Mikes email is
mike@bowltech.com
Re: dist.
Found a picture right here in bowl-tech yellow pages! Under- North Star supply corp. Look at the catalog index and view.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
