pit lights
pit lights
I read somewhere that the new duel lamp pit lights could be purchased cheaply at a place in Everet, Washington; can someone confirm this? I had printed out the phone number and of course it has disappeared. I can be reached at stalker@alaska.net and I thank you for responding.Pinspotters do not break down when they are not running!Tags: None
Re: pit lights
Doc, I'm looking for the fixtures with the spring loaded sockets for the 1 inch 30's. AMF wants $400 each or some ridiculous amount like that. Just like Complete, they wanted $280 for a 120v vacuum motor for our phoenix and we bought them at Grainger for $88.
[This message has been edited by Mike Stalker (edited 01-29-2001).]Pinspotters do not break down when they are not running!
Re: pit lights
[QUOTE]Originally posted by Mike Stalker:
[B]I read somewhere that the new duel lamp pit lights could be purchased cheaply at a place in Everet, Washington; can someone confirm this?
Mike,
The name of the company is The Lighting Store. I paid $79 for each fixture, they came with 1 daylight bulb and 1 blacklight bulb. Alson included was a toggle switch that we mounted in an existing hole in the p box. Run some BX cable from the top of the fixture to the p box and the changeover to blacklight is a simple walk down the catwalk. The phone number is : 1-888-746-5483
Ask for Jean and tell her Plaza Lanes in Madison, NJ reffered you.
Thanks,
Jason
[This message has been edited by GM (edited 02-03-2001).]
Re: pit lights
82/70 king:
I converted all of the orginal fixtures
on the pinsetter to dual lamps.
82/70 king:
spring loaded ends a avaiable at any "good"
electrical supply store. as for a complete
fixture, you might end up buying the whole
thing.
doc
Re: pit lights
i used the fl neon tubes which needs a trannsformer for every six lanes, one lane lights up six lanes. price that i recall was $65 per lane. p.s. regular pins glow with this system. they come in different colors but i only have the bright blue.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Re: pit lights
Well guys I got a hold of The Lighting Store in Everett Wash. I guess those lights someone got from them at $79.00 each was a while ago. I Just talked to them (C J )and they are now $129.00 each. How did some of you go about making your own?
thanks, RonRon M
Re: pit lights
Quote:]<font face="Verdana, Arial" size="2">Originally posted by Ron:
thanks, Ron</font>[/QUOTE]
Ron, it was two year's ago.
Ed
------------------Please buy MADE IN USA!
Re: pit lights
Ron,
Pick up a dual light fixture at your local store. Take out the dual bulb ballast & put in the single bulb ballast from your existing unit. Pay attention to how your old fixtures are wired & copy it in the new fixture. Put a toggle switch in so that you can change the ballast feed from one bulb to the other. That's all there is to it.
Mount the old fixture's brackets on the new one using screws, washers & nuts. They make them out of thinner metal these days.
Dutch
