sweep
  • sweep
    i had a machine stuck in continous cycle tonight so i checked c1 and c2 plugs everything looks ok there switched out sa micro switch and thought i had it but now it sputters in and out like its not getting a good signal? checked all connections and switched out sa micro switch again just in case but still just sputters, any ideas on this one guys? thanks for the help. sorry about that was not to specific,sweep starts down stops for a second then goes again then stops through the cycle.
    [This message has been edited by beakerman64 (edited 01-29-2001).]
    Re: sweep
    Beakerman-
    What exactly do you mean by "sputters in and out?" Does the sweep sputter up and down? Does the ball light sputter on and off?
    Do you have a mercury switch? If so, what does it do when you plug that in?
    Is there a worn microswitch wire grounding against other metal occasionally? How about a loose wire in a wire connector? Did you try giving the machine a good swift kick?
    Good luck
    Chad Q.
      Re: sweep
      Gee...I thought that trick only worked on Brunswicks...lol We usually have to kick it twice though...the first time only gets its attention
        Re: sweep
        Check out your s contactor in the chassis to make sure it didn't come apart. It will cause the sweep to continously run. It will be the upper set.
        king
          Re: sweep
          Change the #1 board.
