hand gernade pins
hand gernade pins
<a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank"><a href="http://www.mscdirect.com" target="_blank">http://www.mscdirect.com</a></a></a></a></a></a></a></a></a></a> Quick-Release Pins 3/16" dia. 1"long,.8125"grip length #MU65069239 approx..79cents ea. for a bag of 25. Features a ball-locking mechanism in place of a cotter pin. Check em out!!If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.FieldsTags: None
Re: hand gernade pins
I seriously hope no one out there still uses roll pins on the clutch end (long end) of the driveshaft. I don't know of any way to get the clutch parts off the shaft without
removing the pin, nor do I know of any way to remove the roll pin without driving it out, which 100% of the time will bend the shaft if not supported.
I found, in McMaster-Carr (grainger may have it), the correct length shoulder bolt that fits nicely in the hole and is just long enough to grab the u-joint. I put a nyloc-type nut on its threads, tightening it into the nylon patch as tight as I can with just my fingers. Stays put, and can be easily removed when needed.
Dittos;;;Dutch Have 6 running now for a month will change the other 6 even lanes soon! [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Bowl,
Channel locks will push the roll pin even with the shaft, then grab hold of it with diagonal cutters & pry the pin out. No hammer, no bent shaft. However, we will be looking into getting some of these "hand grenade pins."
Dutch
phone# 1-800-645-7270,QUICK RELEASE PINS page 1145. (hand gernade pins; just sounds & looks right) felix [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
