Just curious?? I'm using 4 1/4 dia.
Survey-Sheaves
Re: Survey-Sheaves
(I hope noone still has those original PBL 3 1/2" machined ones....the ones that send the 6 pounders thru the mask unit)
I have the 5's. Beware: combing these with a smaller sheave on the back end motor offset shaft to reduce the entire pit can result in the ball not making it over the top.
Re: Survey-Sheaves
i measured as soon as i got in. Im usin those 3 1/2ers. also i dont have the nice curvy rails. i got the 90 degree deals at the top.
check out the pictures thread in our forum if ya dont know what im talkin about
Re: Survey-Sheaves
Quote:]Originally posted by BowlEquip:
COORS: I used to work at an AMF center that had those rails. [/QUOTE]
Get outta here!!!...
I thoughth i was the only one in the universe with those!!!
And yes...6 pounders are an easy 1&1/2 ft loft
