Help
  • Help
    Sweep hits number 1 pin when spotter picks up pins after 1st ball. Just barely but enough to make the pin wobble.
    Thanks guys, I'm counting on ya
    Re: Help
    one thought is the ta-2 switch is slightly out of adjustment causing sweep to run through too soon.See if nut on the adj. screw is loose and the screw may have turned out of adjusment. Another thought is the pin is hanging slightly lower than the rest due to an out of adjustmet respot cell. The finger with the adjustment screw may have a worn arm causing too mutch sloppy movement or the screw itself is in too far. The other thing I would check is the sweep itself. If this is a problem that has just recently started I would think it is the cam or the cell. I hope this is helpful and let us know what you found out.
      Re: Help
      Adjust the table cam so the roller is about a finger width away from the table eccentric latch.
      king
        Re: Help
        Spankey:
        Is this an everyday/time occurence?
        If so, the other guys are right. Check your TA2 cam. Another possibility, is your SB adjusted to stop the sweep at 66* exactly?
        If not, check for sweep coasting/bad breaking. This will cause an intermittent problem like that...but if it's severe enough, the machine SHOULD interlock...providing no one has cheated on the SC cam.
        Kinda need to know the frequency of it.
        Cams usually are constant (unless loose). Microswitches can be intermittent.
        Coasting can be intermittent.
        Kat
          Re: Help
          Thankyou guys, I will check all those different suggestions, This is something that just started. Sometimes it does lockup. I looked in my book, but its very vague about how the cams should be adjusted. Thanks again. I will let you guys know what happens. Your great [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
            Re: Help
              Re: Help
              This is something that just started on my Gremlin machine. I will try all these suggestions. Problem is my book is vague on how to adjust the cams. It gives you a start point and then says this is just a good start point. Thanks again guys your great.
                Re: Help
                  Re: Help
                    Re: Help
                      Re: Help
                        Re: Help
                        Ok guys this is what I found, I checked all the cams and adjusted. But what I didn't know was the sweep was drifting slightly and that was repaired by replacing relays in the chassis. That fixed it all. I thank you all for the info and I certainly appreciate you all and this forum
                        Cal
