Combo Motors
Combo Motors
Anybody out there have trouble with Westinghouse Motors gears blowing out? Pinspotters are 12 years old. Motors started going out soon after installation. It's a 32 lane house and so far I have rebuilt 26 table motors and 10 Sweep motors. It appears that the Planets go and take the rest of the gearbox with.Tags: None
Re: Combo Motors
Quote:]Originally posted by poplarpetey:
It's a 32 lane house and so far I have rebuilt 26 table motors and 10 Sweep motors.[/QUOTE]
Pop, I have never heard of such a problem before. My guess would be they are not factory rebuilt and they have inferior parts. If you are using "V" as your supplier for parts the problem will never go away.
Jonas
Re: Combo Motors
I would try disconecting all the springs and the load of the table so the shaft is floating(so to speak), and then loosen up the bearing assembly to let it "seek" its proper place then re-tighten assy..
What did AMF say about all this?
I have two bearings per shaft and don't plan on puting in the plates for fear of this very problem.
Good luck,
Jonas
Re: Combo Motors
Jonas: That's almost exactly what AMF told us to do except that they wanted me to re-drill holes in the bearing plate where the shoulder screws go through and then tighten. I did this on 10 machines but none of the holes were "mis-aligned". Also, because the center went bankrupt and was purchased by new owners, AMF wouldn't do anything. They finally sent us enough parts to do 10 motors and said that was all they would do. Nice.
Re: Combo Motors
Jonas: Be careful on those double-bearing drive shafts when installing a motor onto the shaft. The weight of the motor puts a permanent strain on the cage spline if the motor is tightened without support, such as a prybar under the gearbox. Pry the motor up just a hair while tightening the first bolt to relieve the strain. I think this is why AMF went to the guide plate rather than the inner bearing, to allow for more freedom in motor location. I have the plates and pry them up a bit while tightening. If a shaft is pulled out later, it looks real clean, hardly any wear.
Just a thought.
