Chassis Problem
  • Chassis Problem
    I ran into a problem this past weekend. I have a SS chassis with Omega-tek mk-70 board and expander card.
    [ November 06, 2001: Message edited by: geminix ]
    Re: Chassis Problem
    Bob,
    Did you have a storm go through? I had the same thing happen. If you want to go back on the threads you will find some info. It was the diodes under the m1, m2 or spot relay that were shorted.
      Re: Chassis Problem
      Bob,
      Try removing the diode that goes to the CP-3 capacitor. You do not need the capacitor for the Omega-Tek to operate. Also the capacitor itself could be removed.
      Jamie
        Re: Chassis Problem
        Jamie,
        That was it!. Thanks again!
        Bob
