Cushion shock x-washer pins
I have been replacing the x-washer pins with 1/2 grade 8 bolts and nylon lock nuts and grade 8 flat washers. I got tired of the x washers falling off and balls going into the pinwheel. I replaced all 3 of the pins. They all seem to be working well. The bolts for the cushion shock were free - I used the bolts off some mod4 seating for those.
JerryTags: None
Re: Cushion shock x-washer pins
To each his own.
I would never recommend replacing the pins with bolts for several reasons.
Note:
Never re-use a X-washer. they are a single use item.
Use the correct size and don't over close them.
Properly installed X-washers don't wall off 82-70 machines.
I used grade 8 washers with the x pins....x washers still fell off....1st thing I was tought by the head mechanic....they are a single use item.
Quote:]I would never recommend replacing the pins with bolts for several reasons.[/QUOTE]
OK.............please enlighten us āGā.
Thanks
Charlie [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]Please buy MADE IN USA!
