kicker problems
  • kicker problems
    ANYBODY HAVING PROBLEMS WITH THERE KICKERS LIKE BALLS RIDING THE KICKERS OR SPINNING [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] I'VE HAD THE ZOT PAD ON THE FRONT FILLER PLATE ON 7 OF THE WORST PAIRS I HAD THAT HAD INTERMITTENT PROBLEMS AND HAVEN'T HAD A BALL CALL ON ANY IN OVER TWO MONTHS [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] AND THEY WORK WITH DIFFERENT TYPES OF KICKER ROLLERS ON THEM.
    AND I'M RUNNING THEM ALL WITH TWO SPRINGS AND THEY WORK :p NO MORE HAVING TO SCREW WITH THE SPRINGS [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] THE ONLY THING YOU MIGHT NOT LIKE IS THE PRICE 24.95 AND I DIDN'T PUT THE EXTRA PADS THEY SEND WITH THEM.I'M GOING TO PUT THEM ON THE REST SOON [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    THE PART # IS Z-420-402 CRUD
    Re: kicker problems
    Hey Crud I have kickers but I have no problem with mine I use a full contact kicker wheele with a turn buckle and have been able to put out 50+units of oil and not have problems.
      Re: kicker problems
      [ November 06, 2001: Message edited by: geminix ]
        Re: kicker problems
        BOB
        the pad goes in the same as the old pad,it's shape is like a saw blade :p and they give you two more pads to add on by drilling 4 holes in the plate,but I didn't bother to put them on.the problem your having with the humpbacks is the reason I won't buy them, where you going to get the belt if they go out of business [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] you'll have to put your kickers back in or buy pbl's [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] good luck CRUD [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
          Re: kicker problems
          I put out about 60 units and have zero problems with my kickers. I use all the original AMF parts in the ball door and murrey round kickers wheels with one spring on them. I tried the full contact kickers but I had better luck with the murrey ones. They seem last longer and if a ball does get stuck, they don't grind down to half thier size.
            Re: kicker problems
            Bob,
            I do have a couple of tip on the humpy belt problem. I had 2 separate. They told me to take the ball guides off. I did so. But the machines I had the problems with were the ones I shaped the lift arm to the door rings. I now install the units with the lift arm with the radius supplied to me. This seems to have cured the belt problem. I still have 2 of their white belts in service with the lift arm installed with the factory bend. I havent seen any of the black new belts separate at all.
              Re: kicker problems
              Try this, it will save you 24.00 if it works. Take an old ball lift belt and cut a piece off the side of it,the rib beside the "v". Cut it about 2" long or what ever your main plate width is. Clean the belt piece and the filler plate about 1-2'' above the original ruber srip on the filler plate. In other words,put it in the same place you would the zot strips. Use a real good super glue and watch ball calls go down the drain. You might have to experiment a little to get it inthe right place. I had a couple of lanes that had to go in a different place,like right above the original ruber strip and right below the ruber strip. Trial and error should get you there. Make sure all parts are in good shape and installed properly-should fix almost all ball calls. Would still rather have PBLS.
              Let me know if this works for ya.
              Phill
                Re: kicker problems
                PHILL
                I did try what your talking about a few years ago and it worked,but the front filler plates started breaking [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] after I glued the belt on it took about two month's and the front fillers started breaking,like one a week or more the only thing I can think of is the belt I put on was too thick [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] in my place they like allot of oil,100 units or more [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] I'M with you I like pbl's.oh well one day I might get them,but I'M not holding my breath or anything else CRUD
                  Re: kicker problems
