Buzzing Spot Solenoid
I have a machine that the spot solenoid buzzes when the machine spots pins. It works fine but buzzes like crazy. I have already ruled out a power problem by using a motor test cable and plugging it into the wall. Still buzzes like mad. Any Ideas?Give me a hammer and some duct tape and I can fix it!Tags: None
Re: Buzzing Spot Solenoid
Lemme guess- bowlers are complaining that foul light goes off every time they bowl. You would like to smack the hell out of them for assuming such a nonsense.
Don't worry. The solenoid is going to hell. Soon it will live no more and you can put it out of its misery. Until then it will make an awful noise. Make sure you have a good spare on hand as well as something to remove/replace whatever is holding it to the hook, etc (nut/bolt, pin, piece of a pencil, etc)
RIP, little spot solenoid.
Chaddy
Maybe the mating surfaces are worn so bad its allowing the plunger to go to far into the coil. Try a piece of electrical tape or thin cardboard on each side to compensate for the wear. This could lead to overheating if you go to far, so be carefull.
for sure you can rebuild solenoids, remove the pin at the base of the unit (usually have to drill the head off it and replace with a screw later on), then pull out the 4 spring loaded plates, 2 either side, now the plunger will come out, then pull the 2 side plates that are next to the plunger out, from there the coil just slips out.
i have found that if the spring plates are too buckled down, they restrict the plunger from going in the full distance, which causes buzzing.
thats how it works at my centre anywayi don't need mods, i am a bloody genius
